oiyq2
Apr 03, 2020Follower
Does doing a hard reset on the router wipe the firmware upgrades I have already done?
So I have forgotten my admin password to my RBR50, and my answers to the security questions aren't working. I have it written down, but is far away in another country. What I'm left with is doing a...
Apr 04, 2020Guru - Experienced User
Factory resets only erase users configurations and passwords. Nothing else!!!
Good troubleshooting step if after a FW upate is applied, and something isn't working, do a reset as last resort. Usually fixes problems.
https://www.youtube.com/watch?v=cMw4ePACgc4
https://www.howtogeek.com/434350/how-to-factory-reset-a-router/
oiyq2 wrote:So I have forgotten my admin password to my RBR50, and my answers to the security questions aren't working. I have it written down, but is far away in another country. What I'm left with is doing a hard reset to my router.
However, a couple months ago, I upgraded the firmware to the router.....I was at least 10 versions behind. I had to do some lengthy manual processes to get my router up to speed, before I could use the 'upgrade now' feature.
Furthermore, the only reason I want to get in to my router right now is to upgrade to the latest firmware.
My question is, if I do a hard reset/factory reset, do I lose all the firmware updates I have already done? If so, I would likely just keep it as is for now.
Thank you in advance!
- Retired_MemberApr 04, 2020
FURRYe38 wrote:Good troubleshooting step if after a FW upate is applied, and something isn't working, do a reset as last resort. Usually fixes problems.
wrong again....factory resets are for lost password.....a user shouldn't have to resort to factory resets due to FW updates....wake up
