sg678
May 08, 2019Tutor
Does Ethernet backhaul free up the upper 5Ghz channels as they interfere with my old cordless phone
I have a RBK22 from costco. I installed/configured using the default wireless 5Ghz backhaul as an AP. Its working good but I am lot of interference/static when using my 10 year old cordless phone wh...
ekhalil
May 09, 2019Master
sg678 wrote:
Based on the answers so far, it seems that the answer is no.
I see the following post which has steps to disable. Does it mean that this post is invalid.
https://community.netgear.com/t5/Orbi/Ethernet-Backhaul-Best-Practices/m-p/1688701#M49638
Please note that disabling Daisy Chain (in the advanced wireless settings) frees up the upper 5Ghz backhaul channels orginated from the satellites, so you will then only have one backhaul network originated from the router on the upper 5GHz band.
To disable the router's backhaul network you need to follow the instructions in the link
You can also choose to just reduce the transmission power of the backhaul channel by following instruction in this link.
sg678
May 12, 2019Tutor
ekhalil I can confirm that the solution did not work in my case of RBK22. I followed all the steps. In my case the interface for the 5Ghz bachaul is ath11. I turned off the radio and brought down teh interface. I commited the changes ot the kernel. Observed that the interface comes back up by itself after a minute or 2 and I see that teh 5Ghz fronthaul SSID starts to use the higher band 5Ghz frequncy channel ( 157 in my case ).
root@RBR20:~# config show |grep BACK
wl2g_BACKHAUL_AP=ath01
wl5g_BACKHAUL_AP=ath11
root@RBR20:~# ifocnfig
ifocnfig
-ash: ifocnfig: not found
root@RBR20:~# ifconfig ath11
ifconfig ath11
ath11 Link encap:Ethernet HWaddr 7E:D2:94:46:54:D1
inet6 addr: fe80::7cd2:94ff:fe46:54d1/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
root@RBR20:~# ifconfig ath11 down
ifconfig ath11 down
ifconfig ath11
BROADCAST ALLMULTI MULTICAST MTU:1500 Metric:1
ifconfig ath11
UP BROADCAST RUNNING ALLMULTI MULTICAST MTU:1500 Metric:1
root@RBR20:~# config show |grep endis_wla_2nd_radio
endis_wla_2nd_radio=0
root@RBR20:~# config show |grep radio
wl_radio=1
endis_wla_radio=1
wla_2nd_radio=1
endis_wl_radio=1
root@RBR20:~#
See my SSID LaughingBuddha is showing up as using 157
