CrimpOn
May 24, 2023Guru - Experienced User
Does Firmware v2.7.5.4 Log Attacks?
I have kept logs from an RBR50 for almost four years.*** After updating to v2.7.5.4 in mid-March, the logs no longer contain "Known DoS attacks and Port Scans".
Rebooting the router did not ca...
May 25, 2023Guru - Experienced User
May not be seeing them in the logs. Noticing this on Orbi AX systems as well.
- CrimpOnMay 25, 2023Guru - Experienced User
That's why I am hoping for a counter example. If even one RBR50 running v2.7.5.4 does log attacks, then maybe something is "wrong" with mine.
I doubt that Netgear intended to remove this feature when releasing v2.7.5.4 because it remains a choice in the log setting and in the WAN setup menu.
- JeffgearJul 28, 2023VirtuosoI’m now only seeing NTP and admin logins on this firmware.
- CrimpOnJul 28, 2023Guru - Experienced User
Thanks for the validation. There is not much value in those log entries, so I remain mostly annoyed.
- FURRYe38Jul 31, 2023Guru - Experienced User
Something we've noticed on Orbi AX as well. Possible NG maybe avoiding logging of attacks. Possible false negatives that may or may not be really needed. NG seems to have a long history of logs that are not really helpful. NG maybe getting rid of logging. 🙄
