CrimpOn
May 24, 2023Guru - Experienced User
Does Firmware v2.7.5.4 Log Attacks?
I have kept logs from an RBR50 for almost four years.*** After updating to v2.7.5.4 in mid-March, the logs no longer contain "Known DoS attacks and Port Scans".
Rebooting the router did not ca...
May 25, 2023Guru - Experienced User
May not be seeing them in the logs. Noticing this on Orbi AX systems as well.
CrimpOn
That's why I am hoping for a counter example. If even one RBR50 running v2.7.5.4 does log attacks, then maybe something is "wrong" with mine.
I doubt that Netgear intended to remove this feature when releasing v2.7.5.4 because it remains a choice in the log setting and in the WAN setup menu.
