Jason_tburgess's avatar
Dec 27, 2018
Does my plug in orbi extend the range off the router or the other satellite?
I bought the orbi plug in to extend the range in my house. Does it extend off the router or the other satellite? Also it lists the devises on each satellite but the signal strength is low on the devices using the plug in satellite! How do I fix this or can I?
  • FURRYe38's avatar
    Depends if you have Daisy Chain enabled or not. If Daisy Chain is disabled, the plug in will connect to the router base. If Daisy Chain is enabled, then the plug in may connect to the satellite.
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
    If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
    • Jason_tburgess's avatar
      Jason_tburgess
      We have about 5000. The router is in the basement with the first satellite on the main floor. So way more than 30 feet! The plug in is on the 3rd floor in the master again more than 30 feet. All my devices with the exception of the tv in the basement and the tv on the main floor are connected to the first satellite. Nothing is connected to the plug in in the bedroom except my wifes cell phone! I cant figure out why the master tv and google mini and any other devices wouldn’t be pulling off the plug in to have a stronger faster signal.
      • FURRYe38's avatar
        What FW version are you using on the Orbi router?
        Try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually. So take the check mark out of the box next to Daisy Chain. Apply the setting and reboot the router and then power off all satellites for 1 minute. Power ON the first satellite nearest the router first and let it come to ready. Then power ON the plug and let it come to ready. Might check the satellite 1 to see whats connected to it. Hopefullly you might see the plug connected to it instead of the router.
        Some devices may just connect to the satellite and not the plug be too close to the plug.
