yangyi0318
Apr 15, 2019Aspirant
Does NETGEAR Orbi Pro SRS60 AC3000 work with RBK50
I have an Orbi RBK50 (router + satellite). The coverage is not so good in my house. I plan to buy an extra satellite. I live in New Zealand but RBS50 is not sold in any physical stores in New Zealand...
yangyi0318
Thanks for you reply. The size of my home is about 250 m2 (two floors in total), woden structure. The distance between router and satellite is about 10 meters (straight distance), but on different floors. The connection shall be good, it displays the blue light when syncing.
I know that RBS40 is AC2200 (867 + 867 + 400Mbps). If I use it with RBK50 (AC3000), does it lower the whole system to AC2200? Or just the area covered by RBS40?
Apr 15, 2019Guru - Experienced User
Just the area covered by the RBS40
