BruceMacb
Nov 06, 2016Aspirant
Does Orbi connect to Testra Gateway HFC
peteytesting
Nov 06, 2016Hero
hi
sure as the telstra cable gateway is a router
so you have 2 options
ether find out how to bridge the cable modem ( this may be a problem if you use voip for home phone ) and connect the orbi router behind it in auto ip ( ipoe ) mode
or
leave the cable modem running as it is as connect the orbi behind it and run the orbi in ap mode
btw do you have any structures ethernet cabling in your house
pete
BruceMacb
Nov 13, 2016Aspirant
No Ethernet cablng throughout the hoise - unfortunately. So if I leave the cable running will it effect the stregth of the signal. My initial problem is 2 x concrete walls with steel mesh between the Telstra router and my office.
- peteytestingNov 14, 2016Hero
BruceMacb wrote:My initial problem is 2 x concrete walls with steel mesh between the Telstra router and my office.
no wifi is going to cope with that not even the orbi
have you looked at power line adapters to get the signal to where its needed
