BruceMacb
Nov 06, 2016Aspirant
Does Orbi connect to Testra Gateway HFC
BruceMacb
Nov 13, 2016Aspirant
No Ethernet cablng throughout the hoise - unfortunately. So if I leave the cable running will it effect the stregth of the signal. My initial problem is 2 x concrete walls with steel mesh between the Telstra router and my office.
peteytesting
Nov 14, 2016Hero
BruceMacb wrote:My initial problem is 2 x concrete walls with steel mesh between the Telstra router and my office.
no wifi is going to cope with that not even the orbi
have you looked at power line adapters to get the signal to where its needed
