Ken2122's avatar
Ken2122
Tutor
Oct 16, 2019
Does Orbi have a 'easy' /push-button way to disable automatic FW updates?
I looked at both the dashboard and debug settings, I don't see a option to stop  auto updates of FW. I prefer the ability to update FW manually. did a Google search and found a Telnet command that se...
  • Ken2122's avatar
    Ken2122
    Nov 13, 2019
    Thanks for all the replies. I now see that unless critical, the firmware updates are manual. It seems Netgear removed the red 'update available' from the Orbi app. Based upon the problems I have seen discussed here on the recent FW, I am not updating diddly-squat, I'l let Netgear push the update to me if/when that time comes.
