bkeith4web's avatar
Oct 11, 2022
Does Orbi RBR40 support channel bonding for 2.4Ghz 802.11n client connections?
As the header states.  I have a Vizio TV that supports 802.11n (testing showed it's 2.4Ghz) and a 100Mbps ethernet connection which I'm using now.  I'm wondering this because if the RBR40 doesn't sup...
  • plemans's avatar
    Oct 11, 2022
    Again, what do you think channel bonding is?
     Its just using different width channels from 20/40/80hz wide channels.
    Netgear just calls it 20/40mhz coexistence. If you disable it so the 2.4ghz runs at 40hz instead of 20hz, you might be faster but it could also be slower. Reason why is because of channel overlap and the fact that routers/devices can't broadcast if something else on that channel is broadcasting. so if you're in a crowded wifi area and you're using "wider" channels, more devices interfere with your routers ability to broadcast. I usually only recommend people use 40hz wide channels (for 2.4ghz) if they're in a rural area or there aren't many 2.4ghz signals that can be picked up. Otherwise, it might be theoretically faster but usually slower or with higher latency/ping times.
