Annomol1
Apr 22, 2020Aspirant
Does Orbi RBR50 speed up the internet
Can the Orbi RBR50 Router & sattelite speed up internet ? and can you also use Netgear AC2200 tri band extender inbetween the Orbi router & satellite to extend signal to an outside location ?
Apr 22, 2020Guru - Experienced User
Orbi only works as fast as your ISP speeds are provided and can only work as well as your connected devices.
No you can not. You'd need another RBS if you want to Daisy Chain them to help extend wifi.
