robsmith406's avatar
robsmith406
Does Orbi RBR50 support multiple internet providers?
I'm looking to get StarLink as a backup internet provider.  Will the RBR50 do the dual WAN thing (failover or load balanced)?   Thanks in advance.
  • CrimpOn's avatar
    Apr 11, 2021
    No, it does not.
    Some users report success with placing a load balancing/failover router in front of the Orbi.
    Ubiquiti EdgeRouter has been mentioned by a number of users for this purpose.
    If you go this route, the big decision is whether to leave the Orbi in router mode or switch it to access point mode.
    Router mode will allow you to use Netgear services such as Parental Control and Bitdefender Armor.  However, that would create a "Double NAT" which is not capable of supporting a number of very specific applications:
    https://kb.netgear.com/30186/What-is-Double-NAT
    Access Point mode eliminates Netgear features, and makes those specific applications possible as long as the "Dual WAN" router supports them. It also places the firwall, DHCP, port forwarding, etc. etc. functions on the new router.
    Good Luck
