BillYoung
Jan 16, 2020Luminary
Does ORBI RBR50 work with GoNetspeed Standard (150 Mbps)
FurryE38 or whomever can help answer this question: We are looking at going to highspeed internet from GoNetspeed. We are looking at the Standard service, which is 150 Mbps. So my question is t...
- Jan 16, 2020
Depending upon modem, modem only unit is recommended. If you get a gateway modem with built in router then you'll need to look into the following:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopOtherwise, speeds will be fine. Mines on a 1Gb/50Mbps ISP service.
Jan 16, 2020Guru - Experienced User
Couple of options,
