Spike13
Nov 03, 2018Guide
Does Orbi Use HT160 Larger Channel Widths?
What exactly are the capabilities of the Orbi system? I find their specs vague and misleading, but maybe that’s just me. For example, I have Spectrum Gig service, 940Mbps wired, and I am barely gettin...
Spike13
Nov 04, 2018Guide
My understanding is that a 2x2 device like the Orbi can theoretically achieve Gigabit speeds over WiFi if it can handle HT160. This would seem to be confirmed by the table posted above. The other option as you mention is a 3x3 device over 80Mhz, which of course the Orbi is not.
None of the specs I’ve seen for the Orbi say much of anything about channel widths, so I had hoped using a 160Mhz channel width was possible. Unfortunately, it seems like that’s not the case, so for any others out there keep in mind the Orbi can only achieve a maximum theoretical link rate of 867Mhz so if your paying a premium for Gig service like I am this may not be the device for you.
Thanks to all for the feedback, very helpful.
Spike13
Nov 04, 2018Guide
And one more lesson learned...Spectrum’s RAC2V1 WiFi routers actually consistently give higher link rates than the Orbi router (867Mhz compared to ~667Mhz, at least when connecting with an Intel 9260 WiFi card), so if you’re looking for speed enhancements over what the stock spectrum equipment gives you the Orbi is not the answer, but it will provide the convenience of one network over a large area.
