jiism
Nov 28, 2017Aspirant
Does RBK50 – Orbi AC3000 Tri-band WiFi System support PoE (Power Over Ethernet)?
Hi, I just brought home RBK50 (2 units system) and have a quick question. Does Orbi Wifi support PoE devices (e.g. POE IP Security Cameras)? I did not find information in the PDF online manu...
st_shaw
Nov 28, 2017Master
Orbi does not provide PoE output power on any ports. You can, however, connect a PoE-enabled switch to Orbi and power cameras that way.
jiism
Thanks. To Netgear Support team - if this information is not in the manual, this is a request to add it to the manual.
