emmpit
Dec 06, 2020Follower
Does RBR50 Router Support WPA3?
I use an RBR50 Orbi router with firmware updated to latest version 2.71.60. The documentation says that on wireless settings under security you can select WPA3 option, however when I log into the rou...
schumaku
Dec 07, 2020Guru - Experienced User
5. Under Security Options, select a WPA option:
• WPA2-PSK [AES]
• WPA-PSK [TKIP] + WPA2-PSK [AES]
• WPA3-Personal [SAE]
The WPA3 option uses the newest standard for the strongest security.
Some older computers and WiFi devices cannot use WPA3 or WPA2. If your network includes old computers and WiFi devices, select the WPA-PSK [TKIP] + WPA2-PSK [AES] radio button.
Said that: What is shown here would be a WPA3-SAE mode _only_ - not supporting any mixed mode (known to cause interoperability issues for many popular wireless client devices - read these fail to associate to the wireless access point).
Have not spotted any indication of WPA3 support in the recent RBR50 firmware release notes however.
Christian_R please provide insight.
