emmpit
Dec 06, 2020Follower
Does RBR50 Router Support WPA3?
I use an RBR50 Orbi router with firmware updated to latest version 2.71.60. The documentation says that on wireless settings under security you can select WPA3 option, however when I log into the rou...
Blanca_O
Mar 01, 2021NETGEAR Employee Retired
Hi, All,
Orbi AC device are not compatible with WPA3 security.
Which security features does my Orbi WiFi System support?
Blanca
Community Team
- schumakuMar 01, 2021Guru - Experienced UserTechnically there is nothing stopping Netgear from making WPA3-Personal available on Qualcomm IPQ4019 abgn+ac 2x2:2 (the first WPA3 certified Mesh system was already qualified in 2018 on the very same chipset) as well as Qualcomm QCA9984 an+ac 4x4:4 for the backhaul are supporting it for a long time.
