thetwin
Aug 16, 2017Aspirant
Does RBR50 support USB connected HDD?
I would like to connect my encrypted USB drives to the Orbi RBR50. Is this feature currently supported? Thanks.
- Aug 16, 2017I know it beacause I talked to Netgear support about this feature and they told me it will be coming in future firmware updates.
OrbiExpert
Aug 16, 2017Guide
Right now it is not supported but in the upcoming firmwares it will be supported.
- DezMAug 16, 2017Star
How do you know HDD support is coming in future updates?
- OrbiExpertAug 16, 2017GuideI know it beacause I talked to Netgear support about this feature and they told me it will be coming in future firmware updates.
Thanks. I hope sooner, than later.
- thetwinAug 21, 2017Aspirant
Thanks for sharing the scoop.
