blarsony
Jul 22, 2020Follower
Does the CBR40 support satellite units?
Looking to pruchase the Orbi CBR40 for use with my Sparklight (CableOne) service and would like to add a satelite unit for the house. Is there a seperate unit to purchase for this, or is the CBK40 the same spec unit that comes with a Satelitle extender?
Sort By
You can add satellites.
The compatible ones are:
RBS20
RBW30
RBS40
RBS40V
RBS50
RBS50Y
Just keep in mind the 50 series won't run at the full 1733mbps backhaul they're capable of because the CBR40 only supports 866mbps backhaul.
EX7500, EX7700 and EX8000 should work aswell.
