Reagten
Sep 11, 2017Aspirant
Does the Orbi have ethernet backhaul?
We need to buy a mesh system NOW. I like that the Orbi gets the highest marks for performance on many review sites, but if it doesn't support ethernet backhaul, then this is a deal breaker. No, ...
TheEther
Sep 11, 2017Guru
First off, Orbi is not really a mesh system. In a mesh system, a satellite can send traffic through another satellite. Orbi can't do that. All satellites must connect to the base station.
Second, Orbi's greatest asset is its wireless backhaul. It would be a waste to spend hundreds of $ and not use it. If you have an Ethernet backbone, then you should be looking at deploying Access Points.
Reagten
Do access points allow seamless hand off from one AP to another?
- peteytestingSep 11, 2017Hero
the first question is why do you need to buy a mesh system NOW ?
whats the user case that needs it now and why
yes in exactly or nearly exactly the same way all of these mesh /dw systems do and none of them are actually seamless , in the end its the client devices that must choose to disconnect from one transmission to then connect to the other
we have been using wireless access points for years in schools and offices and the like and have had no issues , all that needs to be done is down scaling to suit the home needs
a good stand alone router and a few well placed wireless access point will deliver at least as good as any mesh/dw if not better in regards to throughput
suggest you look at something like a ubiquiti edge router and a few ubiquiti unifi AC lite AP's
- TroyusrexSep 23, 2017Aspirant
The use case for me is that I have a house using Orbi, a small detached office, and a Carriage house. All are passive solar built and with a mesh wire layer holding the outside insulation on meaning they all act like Faraday cages and wireless signals do not go through the walls well. Orbi is FANTASTIC for my house. I don't have ethernet run throughout the house so the wireless backhaul is great I used to have to have multiple SSIDs around the house which is a real pain.
Unfortunately, Orbi is almost worthless for the other buildings as they can't take advantage of the wireless backhaul. So I use Orbi in my house, with ethernet over powerline out to the other buildings and separate APs with different SSIDs out there.
The IDEAL solution would be all Orbi with all the same SSIDs. So, the 2 internal satellites would use wireless backhauls while the other buildings would have an Orbi with a wired backhaul. This way there'd be no switching no matter where on the property I am.
I understand that my use case is very rare, and I'm sticking with Orbi for the house even if they never get a wired backhaul. But, the minute they do get the wired backhaul I'm getting two more satellites and wiring them up.
- TheEtherSep 23, 2017GuruSet your APs to use the same SSID as the Orbi. Problem solved.
- TheEtherSep 11, 2017Guru
Leaving enterprise gear out of the discussion, keep in mind that hand off is generally decided by the device, not by the access point. AFAIK, even the Orbi won't initiate hand off of a device between satellites.
Whether or not the hand off is seamless really depends on the aggressiveness of the device's roaming algorithm. Most smartphones are not aggressive; they are very sticky. This often results in a poor handoff experience.
The hand off experience will also depend on the placement of the access points. Place them too closely and a device may not roam. Too far apart and there will be dead spots. I've seen recommendations in some enterprise guides for 15%-20% overlap between Wi-Fi cells, where the edge of each cell is -67 dBm.
Some consumer grade access points are now starting to support the trio of protocols, 802.11r/k/v, to facilitate fast BSS transition (aka fast roaming) but these are really designed to combat the high costs of hand off in an enterprise setting. In a home environment, they may not offer much or any improvement. In addition, a few brands do offer a minimum RSSI setting that will kick a device off in order to force it to roam. But this can hardly be considered a seamless hand off!
- thebishopSep 13, 2017Apprentice
First off, Orbi is not really a mesh system. In a mesh system, a satellite can send traffic through another satellite. Orbi can't do that. All satellites must connect to the base station."
Actually, now with 2.0 firmware it is. As Daisy-Chaining was enabled.
- peteytestingSep 13, 2017Hero
yup
yup and it works , not exactly mesh but dam close
