Reagten
Sep 11, 2017Aspirant
Does the Orbi have ethernet backhaul?
We need to buy a mesh system NOW. I like that the Orbi gets the highest marks for performance on many review sites, but if it doesn't support ethernet backhaul, then this is a deal breaker. No, ...
Reagten
Do access points allow seamless hand off from one AP to another?
peteytesting
Sep 11, 2017Hero
the first question is why do you need to buy a mesh system NOW ?
whats the user case that needs it now and why
yes in exactly or nearly exactly the same way all of these mesh /dw systems do and none of them are actually seamless , in the end its the client devices that must choose to disconnect from one transmission to then connect to the other
we have been using wireless access points for years in schools and offices and the like and have had no issues , all that needs to be done is down scaling to suit the home needs
a good stand alone router and a few well placed wireless access point will deliver at least as good as any mesh/dw if not better in regards to throughput
suggest you look at something like a ubiquiti edge router and a few ubiquiti unifi AC lite AP's
