Reagten
Sep 11, 2017Aspirant
Does the Orbi have ethernet backhaul?
We need to buy a mesh system NOW. I like that the Orbi gets the highest marks for performance on many review sites, but if it doesn't support ethernet backhaul, then this is a deal breaker. No, ...
TheEther
Sep 13, 2017Guru
What makes it not mesh?
rhester72
Sep 13, 2017Virtuoso
With many nodes, mesh will keep track of fastest path and reroute as needed (which also makes it self-healing). Netgear can't (currently) do that, but Eero and Google does.
Rodney
- TheEtherSep 14, 2017GuruDo the chained satellites still use the dedicated backhaul to communicate with their upstream satellites? Or does it behave more like a traditional repeater?
- peteytestingSep 14, 2017Hero
TheEther wrote:
Do the chained satellites still use the dedicated backhaul to communicate with their upstream satellites? Or does it behave more like a traditional repeater?yes , it uses the 5 gig backhaul , but you dont see the 50% loss of a repeater as the backhaul has twice the capacity of the front haul so it pretty much counteracts any loss , however if you daisy chaimed a few back to back i would guess you would see demionishing returns throughput wise
