Reagten
Sep 11, 2017Aspirant
Does the Orbi have ethernet backhaul?
We need to buy a mesh system NOW. I like that the Orbi gets the highest marks for performance on many review sites, but if it doesn't support ethernet backhaul, then this is a deal breaker. No, ...
TennisNJ
Nov 26, 2017Aspirant
Hi, your first statement is not correct. With firmware v2.0.0.74 supports mesh topology. Check release notes/page of Orbi v2.0.0.74 update. This is from Netgear firmware page:
New Features and Enhancements:
Supports daisy-chain topology, which allows Orbi satellites to connect to other satellites or to the router.
Glad at least this feature was added. I haven't tested this yet so can't speak to it or confirm it. Hope this helps.
DarrenM
Dec 05, 2017Sr. NETGEAR Moderator
Orbi now supports Ethernet backhaul with the latest firmware.
https://community.netgear.com/t5/Orbi/Announcing-availability-of-OrbiOS-2-1/m-p/1448279#M16930
DarrenM
- TroyusrexDec 05, 2017Aspirant
Yay! I just ordered another satellite. I'll let you know how well it works.
- TroyusrexDec 09, 2017Aspirant
I got an additional satellite, upgraded the firmware, plugged it into the ethernet and it works like a charm! My "ethernet" is actually via powerline and a pair of Ubiquiti Nanostation M5s, but it still worked without a hitch (it did take a good 15 minutes to synch, but since it finished yesterday it's been working great).
- wserbiaDec 09, 2017Tutor
What steps did you take to enable the ethernet backhaul and how can you tell it is working?
