RedBatman89
Nov 17, 2019Guide
Does the Orbi team have any plans to allow separate SSID in a patch soon?
I'm asking since with some of the latest mesh systems like Google Nest to allow it, will Netgear finally give us the option to seperate 2.4ghz and 5ghz as well?
Ragar99
Nov 18, 2019Luminary
Are you sure Google allows separate bands?
"Your Wifi point(s) keeps it simple by automatically choosing the band that gives you the best Wi-Fi."
https://support.google.com/wifi/answer/6293481
