nm835
Nov 05, 2020Aspirant
Does the Oribi RK83 support additional wifi networks other than primary + guest?
Does the Oribi RK83 support additional wifi networks other than primary + guest? I have lots of smart home devices a few of which have difficultly connecting to wifi's networks which have dual 2.4 a...
nm835
I just found this post:
It provides instructions to login via Telnet and have some settings changes using command line settings.
If anyone knows this works on the new Oribi let me know.
When this is done does anyone know if this separate network is then listed and managable via the browser GUI ?
Thanks !
