PHX_aek
Apr 15, 2021Aspirant
Does unchecking "Enable 5G" do the same as Disable SSID?
Model: Orbi RBR850 w/ 2 Orbi RBS850 Satellites I'm trying to disable broadcasting of the 5Ghz SSID temporarily from my Orbi but I haven't found a menu path in the Router webpage to do this. The...
Apr 15, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi AX product. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
No, thats for enabling AX mode on 5Ghz or disabling AX Mode.
Thank you.
