PHX_aek
Apr 15, 2021Aspirant
Does unchecking "Enable 5G" do the same as Disable SSID?
Model: Orbi RBR850 w/ 2 Orbi RBS850 Satellites I'm trying to disable broadcasting of the 5Ghz SSID temporarily from my Orbi but I haven't found a menu path in the Router webpage to do this. The...
CrimpOn
Apr 15, 2021Guru - Experienced User
Just for future reference, images placed "in line" using the Photos icon on the menu bar do not appear to others until approved by a forum moderator. There are not very many moderators, who are covering all of the Netgear community forums, so that sometimes takes hours (or days!). Images "attached" using the Browse button in the lower left appear immediately.
I have NO IDEA who thought this was a good idea, but "it is what it is".
