chouchou7
Jul 03, 2019Aspirant
Does using an ethernet backhaul free up the 5Ghz band previously used for wireless backhaul?
My understanding is that while the orbi is triband, one of the 5Ghz bands is a dedicated band specifically for using the wireless backhaul. However if I switch my satellite into ethernet backhaul do...
CrimpOn
Jul 03, 2019Guru - Experienced User
I believe the answer is, "Yes... BUT". If my memory is correct, ekhalil posted a method using telnet to disable the backhaul radio, but the backhaul channel does not become available for other use. In other words, it can be done but there isn't any point to doing so.
https://community.netgear.com/t5/Orbi/Issue-with-Orbi-RBR50/m-p/1735885
(I have not tried this myself, and the hack was posted before the latest firmware release.)
chouchou7
Jul 04, 2019Aspirant
Found some old answers and actually, No. Bud did not know the new firmware support it or not.
