gtap
Feb 27, 2020Aspirant
Don't buy an Orbi... firmware removes functionality and causes wifi performance to be terrible...
So I bought my Orbi at the end of 2018... I had a faulty unit to start with but then it got replaced and I got one that worked and set it up. For the most part it kind of worked but frankly their cl...
- Feb 28, 2020
Channels are limited on the Orbi. Especially on 5Ghz. The upper channels are hidden due to that the 3rd backhaul wifi radios are using these channels, 149 and up. These are not configurable by users and auto used by the system. So this leaves the lower 4 channels on the 2nd 5Ghz radio that users can change.
NG has always been kind of backwards in there naming and check box conventions. So when it comes to Orbi, just remember that having a check in the box ENABLES the feature, taking the check mark out of the box, either disables the feature or in case of the 20/40Mhz Coexistence, changes the feature to 40Mhz only. WMM should always be enabled. I think it is by default even after a factory reset.It's up to wireless devices to pick and choose the signals they connect to. Orbi only provides the platform and singals to connet too.
Bulding materials can cause problems for WiFi signals. Concrete and metal are to great for 5Ghz.
Glad the system is up and running better. I think a reset and setup from scratch when you get time will be all thats needed. Be sure to safe off a new backup configuration to file when you done getting the system back up and running as you like.
Maybe this changes your mind about "Don't buy an Orbi". :smileywink:
Please mark your thread as solved so others will know.
Enjoy. :smileywink:
gtap wrote:Thanks again for the advice. I have already upgraded the firmware now to 2.5.1.8 on all the devices. I will see if I can do the factory reset over the weekend (can't risk it now with my work).
What I still don't get is why they think Orbi users should not manage some of their wifi settings... and why they lable things like WMM not entirely correctly. Did you know that checking that box turns off 802.11ac? As much as I understand (which is limited in truth) that should simply remove the QoS that prioritizes streaming services and not touch the wifi configuration. My R7000 let's me choose channel (even above 100) & mode... did I miss something when those got combined into WMM?
I suppose the good news is I'm back to my usual 200Mbps internet speed again in my office... need to see why it's still though producing poor signal in places... doesn't really make sense to me... the router in my office is less than 5m for a BlueSound PowerNode 2i in the adjacent room and yet the Bluesound device is connecting to the main router which is one floor below and at least 10m away. Makes no sense. In general also if I have one wall the signal drops significantly... I know it will drop but seems like my R7000 copes with walls better. I just feel like I'm not understanding something.
gtap
That's also interesting as I have been sitting here for months clicking on check firmware and it kept coming back to say I had the latest... but as you point out it seems I did not. Feeling a bit dim now not having checked the site too.
Do I really need to setup from scratch (factory default)? Will give it a go without.
I'll give you lots of credit at this point you are restoring my faith somewhat so I appreciate it.
Have you tried their Wifi 6 version yet? Will it make any real difference appart from cost me a fortune :-).
Thanks
Feb 27, 2020Guru - Experienced User
Sometimes the Orbi FW check doesn't pick up on updates. I think it also depends on if NG makes it available on there servers.
Try the update first with out a reset, If nothing changes, try the reset and setup from scratch. You should be able to enable Beamforming, WMM, 40Mhz only and MIMO. If you don't have any MIMO supporting devices you can leave this off.
I have both RBK50 and RBK853 online currently.
- tomschmidtFeb 27, 2020Virtuoso
It has been reported that the v2.5.0.x firmware releases leave some garbage behind. Before doing a factory reset and upgrade to v2.5.1.8, your should do the following:
1) Backup your configuration settings (under Advanced tab -> Administration -> Backup Settings)
2) Take a screenshot of every setup screen that you have customized. This can be used in case you restore settings manually in case the backup file also contains unwanted garbage or clutter (i.e. MAC addresses of old devices that connected to your network months ago).
3) Upgrade the firmware on the RBS50 satellites first to v2.5.1.8
4) Upgrade the RBR50 firmware to v2.5.1.8 manually
5) Reset the router to factory settings
6) Configure the router to the point where you can restore you settings saved in step 1
7) If the settings are still corrupt or the system is not working correctly, factory reset the router again and setup manually using your screenshots from step 2 as a reference
8) Backup settings again when all is completed
- gtapFeb 28, 2020Aspirant
- FURRYe38Feb 28, 2020Guru - Experienced User
Enjoy. :smileywink:
