Hogwarts
Jun 18, 2020Guide
Don't understand some core things about my new RBR850
So i am three days into my new RBR850's and i dont understand some things 1. I cant get the Traffic meter to show traffic by device. I dont care about the total and cant figure out how to s...
Jun 18, 2020Guru - Experienced User
I agree, I wish they would change the QoS wording. It's a bit misleading.
I don't think NG will be supporting the more advanced QoS features on Orbi since QoS seems to be automatic in it's handling and runs behind the scenes. Something we don't seen on Orbi AC or AX systems.
I presume if you need more advanced features then you may need to find a router that supports this, like NGs R, RAX series routers.
I personally wouldn't connect a garage door to wifi. Most garages have remotes already. You could install a sheep wired AP in the garage which would be one suggestion.
Good Luck.
Hogwarts
Jun 18, 2020Guide
Its my car that needs the WIFi connection. for software updates
FURRYe38 wrote:I agree, I wish they would change the QoS wording. It's a bit misleading.
Good Luck.
