Ashdli
Oct 06, 2020Tutor
Doorbird video doorbell connectivity issues
I have one router and 2 satellite configuration setup at home providing a 10.0.x.x network. My Telco router sits in front of Orbi and has a 192.168.x.x network. I have a video doorbell from Doorbir...
CrimpOn
Oct 06, 2020Guru - Experienced User
Ashdli wrote:When i shifted to Orbi, i connected all home devices to Orbi network (10.0.x.x) leaving the Telco modem to be just an interaface to the telco provider. I cannot remove the telco modem it as telephone (land line) connectivity is through this modem.
I, also, get telephone service through my ISP modem, but it is only a modem. Generally, the "phone support" and router/WiFi capability are separate functions within the ISP device. The ISP device could be put into bridge (or passthrough) mode without affecting phone service. Perhaps yours cannot, but it is a question that could be put to the ISP technical support.
Ashdli wrote:The issue I face is that Doorbird works perfectly when connected to Telco modem but if I try to connect it to Orbi router , it just stops working. Both connections are wired using the same cable on modem and orbi end.
Just to be clear, the diagram shows the doorbell connection as a solid line, similar to the wired connection between modem, Orbi, and switch. But the doorbell connection is WiFi, correct? Those static IP's are set on the doorbell itself, or on the WiFi router?
Ashdli
Oct 06, 2020Tutor
Thanks Doorbird is connected through a wired connection.
Static IP is configured on Modem. Doorbird does not have wired connections settings, rather only connect to wifi network. It seeks settings from the access points
- CrimpOnOct 06, 2020Guru - Experienced User
Ashdli wrote:Thanks Doorbird is connected through a wired connection.
I am having a slow day. I see that the Doorbird receives electrical power through the doorbell low voltage circuit, but that is entirely different from the network connection.
If the static IP is set on the ISP router (modem), then it cannot be given a 10.0.0 IP address. The ISP router has no idea where that network is because it is hidden behind the Orbi router.
- AshdliOct 06, 2020Tutor
Apologies did not clarify this.
Doorbell is currently physically connected by ethernet cable to Telco Modem and therefore given a 192.X.X.X Ip from this modem.
Only after I move doorbird ethernet cable to Orbi, do I plan to give it a fixed IP from Orbi router of 10.X.X.X
So sequene of actions will be
- Move Doorbird ethernet connection from Telco Modem
- Re-Connect Doorbird ethernet to Orbi.
- Remove static IP (192.X.X.X) allocation for Doorbird in Telco Modem.
- Add Static IP allocation (10.X.X.X) for Doorbird in Orbi.
- Restart Doorbird to pick the new IP adress now in 10.X.X.X range.
I have done the above process earlier and after this I could not connect back to Doorbird. This is the core issue.
Ashdli wrote:Apologies did not clarify this.
Thanks for clarifying. So, the issue appears to be intellectual curiosity as to what causes the smartphone apps to no longer receive alerts from the Doorbird when connected to the Orbi? i.e. if left connected to the ISP router, "everything works?"
These IoT things that connect "through the cloud" are somewhat of a mystery. Perhaps the smartphone app needs to be reconfigured? i.e. Delete the Doorbird from the app and redefine it after it connects to the Orbi?
