RedBatman89
Nov 25, 2019Guide
DOS attack from Germany now?
This has been showing in my logs recently. [DoS Attack: SYN/ACK Scan] from source: 148.251.48.231, port 50002, Monday, November 25, 2019 09:42:27 https://www.ipinfolookup.com/148.251.48.231 ...
Killhippie
Dec 01, 2019Prodigy
I'm having the same, my logs get filled with attacks from this IP to the same port or port 50003. All this has happened since the firmware update for me the other day, and the router has been factory reset. I have a static IP, but the DoS logs starts as soon as the router boots up with literally everything else turned off. Really odd.
- Ken2122Dec 01, 2019Tutor
Interesting. I rarely check my logs (guess I should).....since October 31, 2019, I am getting hammered everyday by DoS attacks. Looks like Orbi is doing its thing and blocking. My ISP is Comcast. I have an Orbi RBR50 (FW v2.3.5.30).
[DoS Attack: SYN/ACK Scan] from source: 194.88.104.9, port 80
DoS Attack: TCP/UDP Chargen] from source: 80.82.77.245, port 50535
[DoS Attack: SYN/ACK Scan] from source: 195.201.167.44, port 443
I may check-out Reddit-Comcast or DSLReports-Comcast to see if others are reporting an uptick.
- FURRYe38Dec 01, 2019Guru - Experienced User
Id contact your ISP and have them help you with this as well. See if they can get you a different WAN IP.
whois.domaintools.com
Ken2122 wrote:Interesting. I rarely check my logs (guess I should).....since October 31, 2019, I am getting hammered everyday by DoS attacks. Looks like Orbi is doing its thing and blocking. My ISP is Comcast. I have an Orbi RBR50 (FW v2.3.5.30).
- KillhippieDec 02, 2019Prodigy
MY ISP is saying its the router calling for something or a vulnerability but nothig to do with them. Also changing IP (mines static) will not help if its a router issue. <sigh> My log looks like this but with hours and hours more of them.
[DoS Attack: SYN/ACK Scan] from source: 148.251.48.231, port 50002, Monday, December 02, 2019 12:52:34
[DoS Attack: SYN/ACK Scan] from source: 148.251.48.231, port 50002, Monday, December 02, 2019 12:52:25
[DoS Attack: SYN/ACK Scan] from source: 148.251.48.231, port 50002, Monday, December 02, 2019 12:52:16
[DoS Attack: SYN/ACK Scan] from source: 148.251.48.231, port 50002, Monday, December 02, 2019 12:51:37
[DoS Attack: SYN/ACK Scan] from source: 148.251.48.231, port 50002, Monday, December 02, 2019 12:51:28
[DoS Attack: SYN/ACK Scan] from source: 148.251.48.231, port 50002, Monday, December 02, 2019 12:51:23
[DoS Attack: SYN/ACK Scan] from source: 148.251.48.231, port 50002, Monday, December 02, 2019 12:50:05
Mines not an Orbi and I'm in the UK. Most strange. Did you update firmware recently?
- FURRYe38Dec 02, 2019Guru - Experienced User
Just curious, Have you tried updating FW to v34 or v40? Factory reset and setup from scratch and see if these still continue.
