RedBatman89
Nov 25, 2019Guide
DOS attack from Germany now?
This has been showing in my logs recently. [DoS Attack: SYN/ACK Scan] from source: 148.251.48.231, port 50002, Monday, November 25, 2019 09:42:27 https://www.ipinfolookup.com/148.251.48.231 ...
Ken2122
Dec 01, 2019Tutor
Interesting. I rarely check my logs (guess I should).....since October 31, 2019, I am getting hammered everyday by DoS attacks. Looks like Orbi is doing its thing and blocking. My ISP is Comcast. I have an Orbi RBR50 (FW v2.3.5.30).
[DoS Attack: SYN/ACK Scan] from source: 194.88.104.9, port 80
DoS Attack: TCP/UDP Chargen] from source: 80.82.77.245, port 50535
[DoS Attack: SYN/ACK Scan] from source: 195.201.167.44, port 443
I may check-out Reddit-Comcast or DSLReports-Comcast to see if others are reporting an uptick.
Dec 01, 2019Guru - Experienced User
Id contact your ISP and have them help you with this as well. See if they can get you a different WAN IP.
whois.domaintools.com
Ken2122 wrote:Interesting. I rarely check my logs (guess I should).....since October 31, 2019, I am getting hammered everyday by DoS attacks. Looks like Orbi is doing its thing and blocking. My ISP is Comcast. I have an Orbi RBR50 (FW v2.3.5.30).
