Christian1955
Mar 15, 2020Aspirant
Dos attack from RBR50 router
Hi My route is filled with this stuff and it chrashes all the time My setup is made of one RBR50 and two sattelites. the system run stable for a few hours and suddently it goes down. Firmware is ...
CrimpOn
Mar 16, 2020Guru - Experienced User
Can you please describe the make and model of the modem the Orbie router is attached to?
Is the Orbi in "router" or Access Point (AP) mode?
- Christian1955Mar 16, 2020Aspirant
Hi
the Orbi router is connected to a Zyxel VMG3925-B10B router from my fiber provider and this Zyxel is put in "Bridge Mode"
The Orbi is in "Router" mode
Maybe you give me a hint to where the "problem" could be! When I was looking at hte back on the Zyxel I could see that it's default IP addresse is 192.168.1.1, and this I also has setup on the ORBI. Could this be the cause of my issue?
I will try to change this to something else.
I will also report back if this is fixing the issue.
/Christian- FURRYe38Mar 16, 2020Guru - Experienced User
Possible. The Orbi uses 192.168.1.1 as it's default, however if the RBR detects the same IP address on its' WAN port, the RBR should and will change it's own IP address to something else, usally a 10 IP address.
However if the modem is fully bridged, the .1.1 IP address should not be seen or used by the modem. Confirm the .1.1. IP address with the MAC address seen in the logs with the sticker on the modem.
