JT_Bauer
Dec 31, 2020Aspirant
[DoS Attack: SYN/ACK Scan]
Disclaimer - I am very new to all this so you will need to dumb it down for me. I know there have been a few other posts about this and I am sorry for adding one more, but I am confused as what I...
Jan 02, 2021Guru - Experienced User
What happens if you put the ISP router back online as your host router and configure the RBR for AP mode?
JT_Bauer wrote:firmware version: V2.7.2.102. And it is connected directly into my fiberoptic modem. It's a 716GE-I R2 Calix. Side Note - I am not using the Netgear Armor. Would that stop it from kicking everything?
Internet was solid using the basic router that CenturyLink gave me. ZyXel C1100Z. Never got kicked. Upgraded to Orbi and nothing but problems.
JT_Bauer
Jan 09, 2021Aspirant
Set it up in AP mode and Orbi router continued to restart as well.
Called support and opened a case with them. Here is what they have tried so far:
Factory Reset - Continued to restart
Changed channel - Continued to restart
Downgraded to 2.3.5 firmware - Continued to restart
I have also tried other power cables from my orbi satellites. I have changed power outlets, even moved it to a completely different floor. Have tried firmare versions 2.7, 2.5 and 2.3.
Starting to think they are going to make me try every random thing under the sun before they replace. Anyone got any other things I should try?
- FURRYe38Jan 09, 2021Guru - Experienced User
Ask about an RMA.
