weichuan
Aug 17, 2021Aspirant
DOS attack UDP port scan from private network address
Hi, I have been getting non-stop DOS attack: UDP port scan from a private network address, is it some device in my network that is causing this issue? Can anyone guide me on how to identify the c...
- Aug 17, 2021
This is called a "Link Local" IP address, which is created by a device when it is unable to get an IP from the network using DHCP.
I would start with the Orbi web interface Attached Devices display All of the devices shown with valid IP addresses (usually starting with 192.168.1) can be ruled out. Are there any other devices connected to the network that are not on the Attached Devices list?
weichuan
Wow, i have too many devices connected. I think the culprit might be the yeelight with WIFI connection for home automation. Seems like one of the light is not connected to the wifi. Let me try turning them off to see if it will solve this issue.
weichuan
Yup, after turning off that light, the DOS attach UDP scan is gone. Thanks!
