itsthelag
Apr 21, 2020Aspirant
DoS Attacks - from varying sources and ports.
Hi There, Since all the working from home started - I've noticed sporadic interruptions while using Video conferencing and while gaming. I will get ping spikes for about 3-5 mins and then it's prett...
Apr 21, 2020Guru - Experienced User
What IP addresses are shown in the logs with these attacks? Any of them 192.168.1.somehing or for external IP addresses?
itsthelag
Firmware is 2.5.1.8, says it's up to date.
Modem is a NG CM 1000.
as for the IPs they are all varying and I'm not positive how to determine if they're from an external address - of the 256 lines I pulled from the log, 125 of them are DoS related. An actual attack doesn't make sense to me, but if not this, what would be causing my newly minted spikes and disconnects while gaming?
| [DoS Attack: SYN/ACK Scan] from source: 45.220.82.227, port 80, Tuesday, April 21, 2020 10:36:00 |
| [DoS Attack: ACK Scan] from source: 35.168.41.214, port 443, Tuesday, April 21, 2020 10:33:37 |
| [DHCP IP: 10.0.0.19] to MAC address f0:6e:0b:e2:ed:a8, Tuesday, April 21, 2020 10:14:32 |
| [DHCP IP: 10.0.0.6] to MAC address f2:54:33:9f:8c:65, Tuesday, April 21, 2020 10:04:19 |
| [DHCP IP: 10.0.0.19] to MAC address f0:6e:0b:e2:ed:a8, Tuesday, April 21, 2020 09:46:07 |
| [admin login] from source 10.0.0.19, Tuesday, April 21, 2020 09:36:16 |
| [DoS Attack: ACK Scan] from source: 52.34.36.246, port 443, Tuesday, April 21, 2020 09:25:53 |
| [admin login] from source 10.0.0.19, Tuesday, April 21, 2020 09:15:02 |
| [DoS Attack: ACK Scan] from source: 3.126.192.149, port 443, Tuesday, April 21, 2020 09:10:50 |
| [UPnP set event: del_nat_rule] from source 10.0.0.14, Tuesday, April 21, 2020 08:58:49 |
| [DoS Attack: SYN/ACK Scan] from source: 213.238.167.92, port 22, Tuesday, April 21, 2020 08:56:44 |
| [DHCP IP: 10.0.0.16] to MAC address d0:c6:37:63:3d:82, Tuesday, April 21, 2020 08:05:11 |
| [DoS Attack: ACK Scan] from source: 52.96.32.2, port 443, Tuesday, April 21, 2020 07:46:39 |
| [DoS Attack: ACK Scan] from source: 216.82.178.25, port 443, Tuesday, April 21, 2020 07:24:45 |
| [DoS Attack: SYN/ACK Scan] from source: 149.202.87.54, port 25565, Tuesday, April 21, 2020 07:07:35 |
| [DHCP IP: 10.0.0.6] to MAC address f2:54:33:9f:8c:65, Tuesday, April 21, 2020 06:57:01 |
| [DoS Attack: RST Scan] from source: 213.29.6.196, port 43589, Tuesday, April 21, 2020 06:10:26 |
| [DHCP IP: 10.0.0.2] to MAC address 3c:37:86:45:88:73, Tuesday, April 21, 2020 05:53:55 |
| [DHCP IP: 10.0.0.3] to MAC address 28:6d:97:a4:66:d8, Tuesday, April 21, 2020 05:53:00 |
| [DoS Attack: SYN/ACK Scan] from source: 43.250.107.198, port 80, Tuesday, April 21, 2020 05:32:16 |
| [DoS Attack: SYN/ACK Scan] from source: 88.198.146.70, port 80, Tuesday, April 21, 2020 05:30:20 |
| [DoS Attack: TCP/UDP Chargen] from source: 71.6.232.5, port 53443, Tuesday, April 21, 2020 05:04:08 |
| [DoS Attack: SYN/ACK Scan] from source: 149.202.139.215, port 25565, Tuesday, April 21, 2020 03:55:52 |
| [DoS Attack: SYN/ACK Scan] from source: 88.198.146.70, port 80, Tuesday, April 21, 2020 03:10:38 |
| [DoS Attack: RST Scan] from source: 185.195.16.201, port 80, Tuesday, April 21, 2020 02:02:49 |
| [admin login] from source 10.0.0.19, Tuesday, April 21, 2020 01:48:01 |
| [DoS Attack: ACK Scan] from source: 52.34.36.246, port 443, Tuesday, April 21, 2020 01:40:51 |
| [admin login] from source 10.0.0.19, Tuesday, April 21, 2020 01:36:39 |
| [DHCP IP: 10.0.0.6] to MAC address f2:54:33:9f:8c:65, Tuesday, April 21, 2020 01:33:58 |
| [DoS Attack: ACK Scan] from source: 52.96.9.5, port 8779, Tuesday, April 21, 2020 01:30:40 |
| [DHCP IP: 10.0.0.5] to MAC address 4c:55:cc:19:29:8f, Tuesday, April 21, 2020 01:26:47 |
| [DHCP IP: 10.0.0.20] to MAC address 08:12:a5:6a:32:76, Tuesday, April 21, 2020 01:26:43 |
| [DHCP IP: 10.0.0.5] to MAC address 4c:55:cc:19:29:8f, Tuesday, April 21, 2020 01:26:02 |
| [DHCP IP: 10.0.0.13] to MAC address 38:53:9c:a3:32:82, Tuesday, April 21, 2020 01:25:52 |
| [DHCP IP: 10.0.0.8] to MAC address dc:f5:05:92:cc:3a, Tuesday, April 21, 2020 01:25:50 |
| [DoS Attack: ACK Scan] from source: 52.96.9.5, port 10937, Tuesday, April 21, 2020 01:25:40 |
| [DHCP IP: 10.0.0.20] to MAC address 08:12:a5:6a:32:76, Tuesday, April 21, 2020 01:25:37 |
| [DHCP IP: 10.0.0.5] to MAC address 4c:55:cc:19:29:8f, Tuesday, April 21, 2020 01:25:31 |
| [DHCP IP: 10.0.0.7] to MAC address fc:a1:83:22:79:30, Tuesday, April 21, 2020 01:25:26 |
| [DHCP IP: 10.0.0.15] to MAC address 64:16:66:af:07:3b, Tuesday, April 21, 2020 01:25:23 |
| [DHCP IP: 10.0.0.9] to MAC address 64:16:66:af:2b:6f, Tuesday, April 21, 2020 01:25:22 |
| [DHCP IP: 10.0.0.12] to MAC address 78:d2:94:2d:a0:b3, Tuesday, April 21, 2020 01:25:20 |
| [DHCP IP: 10.0.0.10] to MAC address 38:f7:3d:01:4f:f0, Tuesday, April 21, 2020 01:25:14 |
| [DHCP IP: 10.0.0.14] to MAC address b4:ae:2b:1a:e0:ec, Tuesday, April 21, 2020 01:25:14 |
| [DHCP IP: 10.0.0.19] to MAC address f0:6e:0b:e2:ed:a8, Tuesday, April 21, 2020 01:25:12 |
| [DHCP IP: 10.0.0.10] to MAC address 38:f7:3d:01:4f:f0, Tuesday, April 21, 2020 01:25:11 |
| [DHCP IP: 10.0.0.4] to MAC address 28:6d:97:b4:de:d3, Tuesday, April 21, 2020 01:24:59 |
| [DHCP IP: 10.0.0.11] to MAC address 00:71:47:47:d3:29, Tuesday, April 21, 2020 01:24:56 |
| [admin login] from source 10.0.0.19, Tuesday, April 21, 2020 01:18:04 |
| [DHCP IP: 10.0.0.5] to MAC address 4c:55:cc:19:29:8f, Tuesday, April 21, 2020 01:06:22 |
| [Time synchronized with NTP server] Tuesday, April 21, 2020 01:06:09 |
| [DHCP IP: 10.0.0.5] to MAC address 4c:55:cc:19:29:8f, Tuesday, April 21, 2020 01:05:01 |
| [admin login failure] from source 10.0.0.19, Tuesday, April 21, 2020 01:04:25 |
| [DHCP IP: 10.0.0.5] to MAC address 4c:55:cc:19:29:8f, Tuesday, April 21, 2020 01:04:08 |
| [DHCP IP: 10.0.0.14] to MAC address b4:ae:2b:1a:e0:ec, Tuesday, April 21, 2020 01:04:00 |
| [DHCP IP: 10.0.0.5] to MAC address 4c:55:cc:19:29:8f, Tuesday, April 21, 2020 01:03:58 |
| [DHCP IP: 10.0.0.12] to MAC address 78:d2:94:2d:a0:b3, Tuesday, April 21, 2020 01:03:57 |
| [WLAN access rejected: incorrect security] from MAC address 8a:d2:94:2d:a0:b3, Tuesday, April 21, 2020 01:03:30 |
| [DHCP IP: 10.0.0.13] to MAC address 38:53:9c:a3:32:82, Tuesday, April 21, 2020 01:03:02 |
| [DHCP IP: 10.0.0.15] to MAC address 64:16:66:af:07:3b, Tuesday, April 21, 2020 01:02:57 |
| [DHCP IP: 10.0.0.9] to MAC address 64:16:66:af:2b:6f, Tuesday, April 21, 2020 01:02:53 |
| [DHCP IP: 10.0.0.8] to MAC address dc:f5:05:92:cc:3a, Tuesday, April 21, 2020 01:02:47 |
| [DHCP IP: 10.0.0.6] to MAC address f2:54:33:9f:8c:65, Tuesday, April 21, 2020 01:02:43 |
| [DHCP IP: 10.0.0.20] to MAC address 08:12:a5:6a:32:76, Tuesday, April 21, 2020 01:02:41 |
| [DHCP IP: 10.0.0.7] to MAC address fc:a1:83:22:79:30, Tuesday, April 21, 2020 01:02:40 |
| [DHCP IP: 10.0.0.10] to MAC address 38:f7:3d:01:4f:f0, Tuesday, April 21, 2020 01:02:39 |
| [DHCP IP: 10.0.0.19] to MAC address f0:6e:0b:e2:ed:a8, Tuesday, April 21, 2020 01:02:39 |
| [DHCP IP: 10.0.0.5] to MAC address 4c:55:cc:19:29:8f, Tuesday, April 21, 2020 01:02:36 |
| [DHCP IP: 10.0.0.11] to MAC address 00:71:47:47:d3:29, Tuesday, April 21, 2020 01:02:33 |
| [DHCP IP: 10.0.0.4] to MAC address 28:6d:97:b4:de:d3, Tuesday, April 21, 2020 01:02:33 |
| [DHCP IP: 10.0.0.10] to MAC address 38:f7:3d:01:4f:f0, Tuesday, April 21, 2020 01:01:56 |
| [remote login failure] from source 10.0.0.19, Tuesday, April 21, 2020 01:01:56 |
| [admin login] from source 10.0.0.19, Tuesday, April 21, 2020 00:58:46 |
| [DoS Attack: RST Scan] from source: 115.79.5.206, port 62831, Tuesday, April 21, 2020 00:53:30 |
| [admin login] from source 10.0.0.19, Tuesday, April 21, 2020 00:47:52 |
| [admin login failure] from source 10.0.0.19, Tuesday, April 21, 2020 00:47:43 |
| [admin login failure] from source 10.0.0.19, Tuesday, April 21, 2020 00:47:32 |
| [DoS Attack: ACK Scan] from source: 52.216.164.115, port 443, Tuesday, April 21, 2020 00:46:53 |
| [DoS Attack: ACK Scan] from source: 3.126.192.149, port 443, Tuesday, April 21, 2020 00:40:46 |
| [DoS Attack: SYN/ACK Scan] from source: 54.39.209.226, port 22, Tuesday, April 21, 2020 00:23:18 |
| [DoS Attack: SYN/ACK Scan] from source: 64.68.121.205, port 80, Tuesday, April 21, 2020 00:13:31 |
| [DoS Attack: ACK Scan] from source: 52.34.36.246, port 443, Tuesday, April 21, 2020 00:10:46 |
| [DoS Attack: ACK Scan] from source: 3.126.192.149, port 443, Monday, April 20, 2020 23:55:46 |
| [DHCP IP: 10.0.0.5] to MAC address 4c:55:cc:19:29:8f, Monday, April 20, 2020 23:28:09 |
| [DHCP IP: 10.0.0.13] to MAC address 38:53:9c:a3:32:82, Monday, April 20, 2020 23:15:41 |
| [DHCP IP: 10.0.0.12] to MAC address 78:d2:94:2d:a0:b3, Monday, April 20, 2020 22:27:29 |
| [DoS Attack: ACK Scan] from source: 3.126.192.149, port 443, Monday, April 20, 2020 22:25:50 |
| [DoS Attack: ACK Scan] from source: 31.13.71.3, port 443, Monday, April 20, 2020 22:03:03 |
| [DoS Attack: ACK Scan] from source: 3.126.192.149, port 443, Monday, April 20, 2020 21:39:48 |
