LoboTommy
Apr 29, 2019Luminary
DoS Attacks....
So, i read up thaht router is blicking DOS attacks, and that the logs tell me it's doing its job. However, I have found it consistant, that every time router blocks a DOS attack, the mesh looses conn...
ekhalil
Apr 30, 2019Master
I usually enter the IP addresses of the DoS attacks that I see in the logs in the Drop IP Tables, and that helps in preventing further attacks.
Unfortunately, the changes are not persistent and need to be entered after every restart :(
Here are my "favourite" DoS IP addresses, I see some of them are the same as the ones listed by LoboTommy :
The list is in ascending IP addresses order (to be able to keep track of new entries) :) :
iptables -I INPUT -i eth0 -s 2.234.127.59 -j DROP
iptables -I INPUT -i eth0 -s 5.9.141.218 -j DROP
iptables -I INPUT -i eth0 -s 5.152.174.78 -j DROP
iptables -I INPUT -i eth0 -s 8.23.224.120 -j DROP
iptables -I INPUT -i eth0 -s 13.74.191.167 -j DROP
iptables -I INPUT -i eth0 -s 17.242.150.30 -j DROP
iptables -I INPUT -i eth0 -s 17.242.150.71 -j DROP
iptables -I INPUT -i eth0 -s 17.252.105.4 -j DROP
iptables -I INPUT -i eth0 -s 17.252.105.11 -j DROP
iptables -I INPUT -i eth0 -s 17.252.105.86 -j DROP
iptables -I INPUT -i eth0 -s 17.252.105.88 -j DROP
iptables -I INPUT -i eth0 -s 17.252.105.138 -j DROP
iptables -I INPUT -i eth0 -s 17.252.105.142 -j DROP
iptables -I INPUT -i eth0 -s 17.252.105.144 -j DROP
iptables -I INPUT -i eth0 -s 17.252.105.151 -j DROP
iptables -I INPUT -i eth0 -s 17.252.108.18 -j DROP
iptables -I INPUT -i eth0 -s 17.252.108.31 -j DROP
iptables -I INPUT -i eth0 -s 17.252.108.32 -j DROP
iptables -I INPUT -i eth0 -s 17.253.52.125 -j DROP
iptables -I INPUT -i eth0 -s 23.101.61.34 -j DROP
iptables -I INPUT -i eth0 -s 23.234.36.31 -j DROP
iptables -I INPUT -i eth0 -s 27.148.157.87 -j DROP
iptables -I INPUT -i eth0 -s 31.11.33.224 -j DROP
iptables -I INPUT -i eth0 -s 31.13.72.8 -j DROP
iptables -I INPUT -i eth0 -s 31.13.72.48 -j DROP
iptables -I INPUT -i eth0 -s 31.220.5.58 -j DROP
iptables -I INPUT -i eth0 -s 35.243.118.183 -j DROP
iptables -I INPUT -i eth0 -s 37.47.238.176 -j DROP
iptables -I INPUT -i eth0 -s 41.216.186.79 -j DROP
iptables -I INPUT -i eth0 -s 45.67.15.69 -j DROP
iptables -I INPUT -i eth0 -s 46.228.172.141 -j DROP
iptables -I INPUT -i eth0 -s 47.75.18.80 -j DROP
iptables -I INPUT -i eth0 -s 51.15.13.28 -j DROP
iptables -I INPUT -i eth0 -s 51.38.94.165 -j DROP
iptables -I INPUT -i eth0 -s 51.68.70.109 -j DROP
iptables -I INPUT -i eth0 -s 52.9.108.157 -j DROP
iptables -I INPUT -i eth0 -s 52.230.13.254 -j DROP
iptables -I INPUT -i eth0 -s 54.36.126.48 -j DROP
iptables -I INPUT -i eth0 -s 54.219.9.206 -j DROP
iptables -I INPUT -i eth0 -s 58.216.107.91 -j DROP
iptables -I INPUT -i eth0 -s 63.143.52.86 -j DROP
iptables -I INPUT -i eth0 -s 66.147.235.214 -j DROP
iptables -I INPUT -i eth0 -s 81.26.227.3 -j DROP
iptables -I INPUT -i eth0 -s 85.10.206.164 -j DROP
iptables -I INPUT -i eth0 -s 85.62.35.156 -j DROP
iptables -I INPUT -i eth0 -s 86.88.28.153 -j DROP
iptables -I INPUT -i eth0 -s 89.248.168.51 -j DROP
iptables -I INPUT -i eth0 -s 90.161.220.80 -j DROP
iptables -I INPUT -i eth0 -s 94.198.137.12 -j DROP
iptables -I INPUT -i eth0 -s 101.69.121.81 -j DROP
iptables -I INPUT -i eth0 -s 103.9.177.50 -j DROP
iptables -I INPUT -i eth0 -s 103.46.13.95 -j DROP
iptables -I INPUT -i eth0 -s 104.18.55.172 -j DROP
iptables -I INPUT -i eth0 -s 104.24.102.104 -j DROP
iptables -I INPUT -i eth0 -s 104.24.107.230 -j DROP
iptables -I INPUT -i eth0 -s 104.194.10.209 -j DROP
iptables -I INPUT -i eth0 -s 107.191.33.88 -j DROP
iptables -I INPUT -i eth0 -s 109.196.247.252 -j DROP
iptables -I INPUT -i eth0 -s 112.26.214.108 -j DROP
iptables -I INPUT -i eth0 -s 113.113.92.90 -j DROP
iptables -I INPUT -i eth0 -s 118.187.15.101 -j DROP
iptables -I INPUT -i eth0 -s 123.129.223.140 -j DROP
iptables -I INPUT -i eth0 -s 142.93.224.70 -j DROP
iptables -I INPUT -i eth0 -s 158.69.225.26 -j DROP
iptables -I INPUT -i eth0 -s 141.212.123.31 -j DROP
iptables -I INPUT -i eth0 -s 144.76.99.209 -j DROP
iptables -I INPUT -i eth0 -s 151.101.86.113 -j DROP
iptables -I INPUT -i eth0 -s 173.249.59.64 -j DROP
iptables -I INPUT -i eth0 -s 174.136.12.130 -j DROP
iptables -I INPUT -i eth0 -s 176.227.171.58 -j DROP
iptables -I INPUT -i eth0 -s 176.227.172.33 -j DROP
iptables -I INPUT -i eth0 -s 178.128.195.200 -j DROP
iptables -I INPUT -i eth0 -s 183.213.21.3 -j DROP
iptables -I INPUT -i eth0 -s 184.105.139.69 -j DROP
iptables -I INPUT -i eth0 -s 184.105.139.89 -j DROP
iptables -I INPUT -i eth0 -s 184.105.139.101 -j DROP
iptables -I INPUT -i eth0 -s 185.50.106.229 -j DROP
iptables -I INPUT -i eth0 -s 185.94.111.1 -j DROP
iptables -I INPUT -i eth0 -s 185.199.111.153 -j DROP
iptables -I INPUT -i eth0 -s 188.130.7.85 -j DROP
iptables -I INPUT -i eth0 -s 188.165.36.150 -j DROP
iptables -I INPUT -i eth0 -s 190.2.130.116 -j DROP
iptables -I INPUT -i eth0 -s 193.19.118.187 -j DROP
iptables -I INPUT -i eth0 -s 193.19.119.242 -j DROP
iptables -I INPUT -i eth0 -s 193.228.143.13 -j DROP
iptables -I INPUT -i eth0 -s 193.228.143.14 -j DROP
iptables -I INPUT -i eth0 -s 195.54.122.198 -j DROP
iptables -I INPUT -i eth0 -s 195.154.36.30 -j DROP
iptables -I INPUT -i eth0 -s 202.36.54.224 -j DROP
iptables -I INPUT -i eth0 -s 203.101.184.121 -j DROP
iptables -I INPUT -i eth0 -s 203.107.42.192 -j DROP
iptables -I INPUT -i eth0 -s 203.107.42.193 -j DROP
iptables -I INPUT -i eth0 -s 206.189.27.197 -j DROP
iptables -I INPUT -i eth0 -s 208.85.241.142 -j DROP
iptables -I INPUT -i eth0 -s 212.8.253.226 -j DROP
LoboTommy
Apr 30, 2019Luminary
Where is that? Like, here? (See attached picture)
How do you set it up?
- CrimpOnApr 30, 2019Guru - Experienced User
LoboTommy wrote:
Where is that? Like, here? (See attached picture)Orbi's web and smartphone apps do not provide a way to enter this information. These commands are entered by using the 'debug' page to enable telnet, opening a telnet session to the router, and then entering these lines. (Most often by copying them from a text file and pasting them into the telnet window.) Since Orbi is built on OpenWRT, which is turn built on a version of Linux, there are dozens of things that someone proficient in Linux can do.
My guess is that 99% of Orbi owners have no idea the debug facility exists and have never used telnet.
- LoboTommyApr 30, 2019LuminarySo, in simple terms for a common man. What do I do? Step by step....? ;-)
