juniormint88's avatar
Feb 06, 2017
DoS Attacks in Logs
Is it normal to see so many "DoS Attack: SYN/ACK Scan" in the router logs? I have AT&T GigaPower.
  • peteytesting's avatar
    peteytesting
    Feb 07, 2017
    well ether devices on your lan that have been torrenting or if you are on a dynamic ip address from your isp it could be who ever last had the ip address , its a pretty commoin thing to see in logs and is just identified wrong , if it does get worse prob time to get someone look into it and assess the security implications
