Hogstead
Oct 23, 2019Follower
Dos Protection Orbi
When logging into the router and reviewing the logs the router claims I am getting multiple Dos attacks in a very short time span. This results in my PC losing internet and gaining it back multiple ...
michaelkenward
Oct 24, 2019Guru - Experienced User
Tried searching this forum for Dos attacks?
They are mostly false alarms and a consequence of Netgear's wonky logging.
If this is locking up your router, then you can disable logging and see if that improves matters:
- Advanced
- Administration
- Logs
- Disable as required.
