BiGMERF
May 07, 2019Apprentice
Double nat issue...
Hey rook here with a quick question...
got a double nat warning on my Xbox one..
running my new Orbi connected to a modem/router combo from century link for my fiber.
So I was doi...
BiGMERF
May 08, 2019Apprentice
yes thank you, I am aware of AP mode.. only issue with that is you loos some features in the process... it also seemed like for some reason while in AP mode my devices where less likely to connect to the sattelites...
Kneby2
May 08, 2019Aspirant
Hi,
Rookie my self, and did the same experience 1-2 weeks ago, when i got my RBR20 + sat.
I did it from the modem(router).
The adress ORBI showed was the WAN adress.
In my modem the orbi was assigned a LAN adress, which i put into the DMZ.
