BiGMERF
May 07, 2019Apprentice
Double nat issue...
Hey rook here with a quick question...
got a double nat warning on my Xbox one..
running my new Orbi connected to a modem/router combo from century link for my fiber.
So I was doi...
SW_
May 07, 2019Prodigy
BiGMERF, assuming you don't need Disney Circle or Armor features, there is a 3rd option, Orbi AP mode, which doesn't require you to tinker with your modem/router settings. Putting the Orbi in AP mode will also shield it from external attacks, i.e., ports scan/sync attacks.
SW_
May 08, 2019Prodigy
Just a data point. An example of the type of regular attacks on my RT-AC87U router. Fortunately, both username/password can be changed on this router, which isn't the case with Orbi. The risk with Orbi in Router mode is a bit higer than AP mode setup b/c the default "admin" username can't easily be changed for example. WIth that said, it doesn't mean that Orbi in Router mode isn't safe!
Apr 21 17:14:10 httpd_login_lock: Detect abnormal logins at 5 times. The newest one was from 200.107.254.70 in login.
Apr 22 16:50:31 httpd_login_lock: Detect abnormal logins at 5 times. The newest one was from 200.107.254.70 in login.
Apr 23 07:07:17 httpd_login_lock: Detect abnormal logins at 5 times. The newest one was from 200.107.254.70 in login.
Apr 24 10:16:29 httpd_login_lock: Detect abnormal logins at 5 times. The newest one was from 200.107.254.70 in login.
Apr 24 15:11:14 httpd_login_lock: Detect abnormal logins at 5 times. The newest one was from 200.107.254.70 in login.
Apr 25 00:40:14 httpd_login_lock: Detect abnormal logins at 5 times. The newest one was from 200.107.254.70 in login.
Apr 25 14:52:05 httpd_login_lock: Detect abnormal logins at 5 times. The newest one was from 200.107.254.70 in login.
Apr 25 19:26:05 httpd_login_lock: Detect abnormal logins at 5 times. The newest one was from 200.107.254.70 in login.
Apr 26 05:08:07 httpd_login_lock: Detect abnormal logins at 5 times. The newest one was from 200.107.254.70 in login.
Apr 27 23:33:30 httpd_login_lock: Detect abnormal logins at 5 times. The newest one was from 200.107.254.70 in login.
Apr 28 04:21:26 httpd_login_lock: Detect abnormal logins at 5 times. The newest one was from 200.107.254.70 in login.
Apr 29 13:02:51 httpd_login_lock: Detect abnormal logins at 5 times. The newest one was from 200.107.254.70 in login.
Apr 29 17:40:36 httpd_login_lock: Detect abnormal logins at 5 times. The newest one was from 200.107.254.70 in login.
Apr 29 22:25:29 httpd_login_lock: Detect abnormal logins at 5 times. The newest one was from 200.107.254.70 in login.
Apr 30 03:04:12 httpd_login_lock: Detect abnormal logins at 5 times. The newest one was from 200.107.254.70 in login.
...May 8 05:02:40 httpd_login_lock: Detect abnormal logins at 5 times. The newest one was from 200.107.254.70 in login.
May 8 09:11:50 httpd_login_lock: Detect abnormal logins at 5 times. The newest one was from 200.107.254.70 in login.
May 8 19:54:31 httpd_login_lock: Detect abnormal logins at 5 times. The newest one was from 200.116.170.72 in login.
May 8 19:59:16 HTTP_login: Detect abnormal logins at 5 times. The newest one was from 200.107.254.70 in auth check.
