ClonedVarient
Jul 11, 2019Aspirant
Double NAT troubles with XBox One
So, Ive got an Orbi Router and 1 Satellite for my internet. Ive called up my ISP and asked if there was any other router between my Orbi and the Internet, theyve already told me no. My setup has th...
ClonedVarient
Jul 12, 2019Aspirant
The IP starts with 192.168 so the ISP guys lied to me or there is something another router..... Im going to have to call them up and see what exactly the installed. Because its just a dish outside with a wire leading inside, which leads to a little black box, which said wire connects to and the Orbi connects to. I had asked them about that little box too, they said it wasnt a router. After I call them up and get a thorough run down of my equipment i will give an update.
Much thanks!
Much thanks!
michaelkenward
Jul 12, 2019Guru - Experienced User
What about the modem in front of the Orbi? What is it?
More likely ignorance rather than a deliberate lie.
