Kmandair04
Nov 28, 2021Aspirant
Double Nat when using AP Mode
I want to use my main fibre gateway router since it has more options and custom options and to do so I did as followed. I put the Orbi into AP mode , and continued to use fibre as main router. Proble...
CrimpOn
Nov 28, 2021Guru - Experienced User
Kmandair04 wrote:
I want to use my main fibre gateway router since it has more options and custom options and to do so I did as followed. I put the Orbi into AP mode , and continued to use fibre as main router. Problem was Orbi was still creating a private network and whenever I would play games online I had horrendous lag and bad ping and packet loss. To fix that I had to put my gateway into bridge mode and put Orbi into router, but it sucks because I lose all custom options for my fibre gateway.
When the Orbi is in Access Point (AP) mode, it does not create any network of any kind. Each of the Orbi units and every device connected to the Orbi use DHCP to request an IP address from the primary router.*
The primary router will create a private network and use NAT to map from the Public IP address to the private IP address for each device.
Depending on the specific game, there may be options to forward ports through the fibre router to the gaming machine.
* An easy method to determine that this is the case is to look at the IP address of every device on the network, including the Orbi router and satellites. Do the all belong to the same IP subnet (such as 192.168.1.x) and is the fibre router the gateway address?
** The forum is often a handy way to learn interesting information. Could you expand on what specific features the fibre router provides that the Orbi lacks? When it comes time to replace my Orbi, it would be handy to have some idea of features to look for.
Kmandair04
Thanks For Responding. Yea I do not have much knowledge with some of the stuff and I assumed it was an Orbi Problem or something. Okay so for the solutions, how do i look up the ip address of all the devices. Will the netgear orbi app help with that or do i have to go to orbilogin.net to find out?.
For the features he fibre router has I just want to be clear its the gateway router my ISP provied us. Main feature is I can make 2.4 and 5.ghz networks with seperate SSID. I can manage all devices including my tv cable which is also from my ISP so its more convinient. I can see how much time and internet usage each device has used and at what time specifcally. Just from the phone app I can port forward, and do some other things that are beyond my knowledge.Its just overall more convinent because my landline, tv cable and internet are all in one place contrallable in the app
