Kmandair04
Nov 28, 2021Aspirant
Double Nat when using AP Mode
I want to use my main fibre gateway router since it has more options and custom options and to do so I did as followed. I put the Orbi into AP mode , and continued to use fibre as main router. Proble...
CrimpOn
Nov 29, 2021Guru - Experienced User
It is quite a mystery that the phone could "show connected" but the application not perform. Most of the complaints about WiFi disconnects involve actual "disconnects" where the device reports losing WiFi signal.
Kmandair04
Nov 29, 2021Aspirant
Yea it is. Do u think I should factory reset my orbi and start up the setup process all over again? Maybe a setup issue is causing this problem?
- CrimpOnNov 29, 2021Guru - Experienced UserCannot hurt. This situation is just weird. Does every device have this problem?
- Kmandair04Nov 29, 2021AspirantLaptops sometimes go buggy in the sense where I’m right beside the router and I’m getting slow wifi speeds sometimes. When upstairs, phone connects to the orbi router downstairs instead of the satellite upstairs thats closer to me
