BastideDesCrete
Aug 02, 2020Aspirant
Download and upload randomly drops every 30seconds for a few seconds then reconnects(RBR20, RBS20)
I got my orbi router (RBR20) and 2 orbi satellites (RBS20) in a pack that came together. It was working fine for a long time but up until the most recent firmware update it started causing a persiste...
- Aug 03, 2020
Your modem seems to have a built in router and wifi already. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
BastideDesCrete wrote:I have tried the settings that you advised but it all doesn't change anything, I am currently trying to use the most stable configuration that you added as well.
And yes I have done a factory reset after the latest update and this hasn't changed anything.
Sometimes the problem occures, whilst at other times the wifi functions normally.
Here is the other information that you have requested:
Firmware: V2.5.1.16
ISP: Orange
Modem Model: Livebox 4
Modem made by: Sagemcom
Orbi system operating in: Router Mode
Size of home (Sq ft): 3000
Distance between Router and satellites: 10m - 15m (30 - 50 feet)
CrimpOn
Aug 02, 2020Guru - Experienced User
BastideDesCrete wrote:Another issue that could be the problem is that it gets quite hot (41*C) and that might have an issue but I doubt it.
Page 158 of the Orbi User Manual lists the operating temperature for the RBR20 as 0 to 40C. (32 to 104F). Modern processors have temperature sensors which reduce the CPU frequency when the system overheats.
https://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
Do you have any method of cooling the Orbi? As an experiment, you could put the Orbi in a cardboard or styrofoam box with some ice and see if the problem goes away. (That is obviously not a permanent solution, but would at least allow a conclusion as to whether the temperature is an important factor.
If the problem did not exist before the recent firmware update, another step would be to download the previous firmware from the Netgear support site and do a manual firmware update. (in this case, a "downdate" - hah) It could be that the latest firmware has placed a higher load on the processor which makes it more sensitive to temperature.
- BastideDesCreteAug 03, 2020Aspirant
Thank you for your very quick response, I checked when the problem was occuring and the temperature was below 40*C so I doubt it is thermal throttling. I haven't decided to revert the firmware update as of yet as I would like to try other solutions but I also don't think it would be this because I haven't seen any other posts about this online.
