BastideDesCrete
Aug 02, 2020Aspirant
Download and upload randomly drops every 30seconds for a few seconds then reconnects(RBR20, RBS20)
I got my orbi router (RBR20) and 2 orbi satellites (RBS20) in a pack that came together. It was working fine for a long time but up until the most recent firmware update it started causing a persiste...
- Aug 03, 2020
Your modem seems to have a built in router and wifi already. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
BastideDesCrete wrote:I have tried the settings that you advised but it all doesn't change anything, I am currently trying to use the most stable configuration that you added as well.
And yes I have done a factory reset after the latest update and this hasn't changed anything.
Sometimes the problem occures, whilst at other times the wifi functions normally.
Here is the other information that you have requested:
Firmware: V2.5.1.16
ISP: Orange
Modem Model: Livebox 4
Modem made by: Sagemcom
Orbi system operating in: Router Mode
Size of home (Sq ft): 3000
Distance between Router and satellites: 10m - 15m (30 - 50 feet)
Aug 03, 2020Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
Has a factory reset and setup from scratch been performed since last update?
BastideDesCrete wrote:I got my orbi router (RBR20) and 2 orbi satellites (RBS20) in a pack that came together. It was working fine for a long time but up until the most recent firmware update it started causing a persistent problem where it would drop the download and upload speeds for a few second (maybe 2 - 5) and then would start again, this would happen every 30s - 60s. Sometimes if I restarted the router it would be fine, but the next day the problem would reoccur. This problem is very annoying if I were to stream, play games or call someone as my connection would drop so often. Another issue that could be the problem is that it gets quite hot (41*C) and that might have an issue but I doubt it.
I have looked everywhere online but I couldn't find a solution. I have tried rebooting it, factory resetting it and this hasn't impacted anything. I was wondering if anyone knew a solution to this? I assume it has something to do with either the firmware update (which I doubt because I can't find any other posts online) or there might possibly be something wrong with the satellite. I have also tested to make sure that it isn't my computer as I have used mobile data on my pc and it doesn't have the same issue.
I have attached a screenshot of task manager when the connection drops when I'm downloading a game.
BastideDesCrete
Aug 03, 2020Aspirant
Firmware: V2.5.1.16
ISP: Orange
- MstrbigAug 03, 2020Master
Does this only happen using WIFI? Or do you experience the slowdown with any wired devices?
If it's just WIFI, it could be packet traffic from other WIFI devices or interference. If interference I suggest changing channels.
It could also be an ISP device or connection issue. I had an intermittent slow down of my download speeds going from 500Mbps down to 300 and upload speeds going from 50Mbps down to 4 or 5, right after switching from Velop to Orbi. After resetting and testing the Orbi, I plugged directly into my ISP modem. I still had the slowdown, so I contacted my ISP. It turned out to be a bad Tap on their side. Now my speeds are rock solid.
- FURRYe38Aug 03, 2020Guru - Experienced User
Couple of options,
Firmware: V2.5.1.16
ISP: Orange
- BastideDesCreteAug 04, 2020Aspirant
FURRYe38 I did step 3, but the issue still occurs, sometimes it works normally and sometimes it doesn't, it doesn't matter if I've rebooted the wifi, it's completely random when it occurs. When I used the router on the modem, it worked fine, so it's definitely Orbi, the only thing I haven't tested is whether or not it's a specific satellite or it's the whole orbi system. I get the feeling it might have something to do with only "orbi satellite 2" but I need to test this.
Something else I've also realized is that the MU-MIMO is causing me to have massive ping fluctuations. (in a game it can be between 40(normal) and 500), I was wondering if I needed that or if I could turn it off.
- FURRYe38Aug 04, 2020Guru - Experienced User
So lets turn OFF the RBS and see if the problem continues with just the RBR running alone.
Yes you can disable MIMO if you don't have any MIMO supporting devices.
BastideDesCrete wrote:FURRYe38 I did step 3, but the issue still occurs, sometimes it works normally and sometimes it doesn't, it doesn't matter if I've rebooted the wifi, it's completely random when it occurs. When I used the router on the modem, it worked fine, so it's definitely Orbi, the only thing I haven't tested is whether or not it's a specific satellite or it's the whole orbi system. I get the feeling it might have something to do with only "orbi satellite 2" but I need to test this.
