BastideDesCrete's avatar
Aug 02, 2020
Download and upload randomly drops every 30seconds for a few seconds then reconnects(RBR20, RBS20)
I got my orbi router (RBR20) and 2 orbi satellites (RBS20) in a pack that came together. It was working fine for a long time but up until the most recent firmware update it started causing a persiste...
  • FURRYe38's avatar
    Your modem seems to have a built in router and wifi already. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    BastideDesCrete wrote:
    I have tried the settings that you advised but it all doesn't change anything, I am currently trying to use the most stable configuration that you added as well.
    And yes I have done a factory reset after the latest update and this hasn't changed anything.
    Sometimes the problem occures, whilst at other times the wifi functions normally.
    Here is the other information that you have requested:
    Firmware: V2.5.1.16
    ISP: Orange
    Modem Model: Livebox 4
    Modem made by: Sagemcom
    Orbi system operating in: Router Mode
    Size of home (Sq ft): 3000
    Distance between Router and satellites: 10m - 15m (30 - 50 feet)
