DGSmith
May 01, 2020Aspirant
Download and Upload Speeds Hindered After RBR50 Router
I just upgraded my internet service to 1Gb/s. Speed are good coming from my ISP modem. But they are drastically reduced after the ORBI Router.
What is the problem or how do I correct?
- DGSmithAspirant
Mfr looks like ZHONE. I do not see a model number.
ISP is Mainstream Fiber Networks (msfiber.net).
- DGSmithAspirant
My Firmware is up-to-date I beleive.
v2.5.1.8
- DGSmithAspirant
ISP just responded:
Zhone 2301
Ok, checking to see if it has a router built in, I don't see one:
https://dasanzhone.com/product/znid-gpon-2301/
Though curious about it's built in QoS features which wondering if it could be causing some issues.
Power OFF the ONT for 1 minute then back on. Factory reset the RBR and walk thru the setup wizard with a wired PC. Complete the setup and run a speed test with Ooklas installable windows or max speed test app. Do not enable Armor, Access controls, Circle, QoS speedtest or Traffic meter. Just run a speed test thru the RBR with a wired PC. Let us know your results.
