Ramboost2000
Dec 21, 2019Aspirant
Download slower than upload
I have just installed Orbi RBK53, and I have serious problems getting proper wifi download speed over WiFi. I have a 500/100 mbit internet connection and when I test my internet speed from eg. my iPh...
Dec 21, 2019Guru - Experienced User
Ramboost2000
Dec 22, 2019Aspirant
The ISP modem is a Sagemcom Fast3890.
- FURRYe38Dec 26, 2019Guru - Experienced User
I Think this already has a built in router with in the modem.
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopWhat is the Mfr and model# of the ethernet switch in the configuration?
